Activity Forums Zaxwerks Illustrator curves gone wonky – Need Solution Fast!
  • Illustrator curves gone wonky – Need Solution Fast!
    Posted by Peter Menich on September 28, 2008 at 11:21 am
    Hey,
    I’ve come across a problem with some extruded type using Invigorator Pro 4.
    Please refer to this jpg…
    https://www.zedzero.co.uk/zaxprob.jpg
    I saved the Illustrator files as version 8, and imported them in to Invig.
    As you can see; in the preview window the curves on the font are all hunky dory, but in the actual comp they’re not!
    I’ve tried dicking about with various settings and gotten nowhere.
    I tried doing them as models through Cinema 4D and importing them, but that seemed to create even more pain.
    I have a Tuesday deadline to deliver this project, so a solution would be a wonderful thing – otherwise I will have to start again from scratch in Cinema 4D.
    Keeping fingers crossed.
    Pete
    Jon Okerstrom replied 17 years, 11 months ago 2 Members · 2 Replies
  • Peter Menich
    September 28, 2008 at 11:48 am
    At ease everyone,
    I did some further poking and found that if I turn the draft settings on the object faceting up to 10, and best settings down to 0.1 it solves the issue.
    A bit counter intuitive, as the preview window seems to do the opposite to what its doing in the comp window – as well as to get better quality you need to decrease the best setting!
    ho hum.
  • Jon Okerstrom
    September 28, 2008 at 7:58 pm
    Hi Peter,
    Draft mode is meant for fast previews of the motion. Bigger numbers result in cruder shapes that render really quickly in preview mode.
    As you’ve discovered, you can use a really small number in the “best” settings to get very smooth curves. If the curves still aren’t smooth enough, you can type in an even smaller number like .01.
    Jon
