Activity › Forums › Adobe Illustrator › illustrator cs3 vector question
  • illustrator cs3 vector question
    Posted by Dennis Moulton on August 25, 2008 at 8:37 pm
    i have illustrator cs3 and i also just purchased a vinyl cutter. now for the vinyl cutting software i need to convert an image to a vector or path format. (eps, ai, ect)so i start with getting an image i want, usually a jpg image. then i put it into illustrator. this is where i’ve tried everything to get the shape of just the picture. everytime i import an image it brings just the rectangle around the whole image. i don’t want to cut a rectangle but the object inside.
    Todd Morgan replied 18 years, 1 month ago 2 Members · 1 Reply
  • Todd Morgan
    August 28, 2008 at 9:14 pm
    It’s called LIVE TRACE and is an option when you have the image selected. It works on high contrast or b/w images and there are a variety of pre-sets. Otherwise, you are looking at creating the vectors by hand.
