Activity Forums Adobe Illustrator Illustrator CS3 – Separate by Color?
  • Illustrator CS3 – Separate by Color?
    Posted by Nick Marques on March 26, 2008 at 9:41 pm
    Hello,
    I have a somewhat complicated logo that I want to sort of explode and separate into groups by color. There are only three colors. How might I do this?
    The Select Similar feature doesn’t really work as I need black separate from yellow, and some paths use black strokes with yellow fill.
    Ideas please!
    Vincent Rosati replied 18 years, 4 months ago 2 Members · 1 Reply
  • Vincent Rosati
    April 30, 2008 at 12:45 am
    Try…
    Select All, than Object/Path/Outline Stroke.
    You should now be able to Direct Select the fills and Select/Same/Fill Color.
    Vince
