Activity Forums Adobe Illustrator Illustrator CS2: Perspective and Spot Colors
  • Illustrator CS2: Perspective and Spot Colors
    Posted by Cynocephalus on December 6, 2006 at 11:52 am
    Hello
    I have the following problem in Illustrator CS2:
    I have text which I want to transform. With the 3d effect I achieve the desired results. BUT, I need to have only Spot Colors and the 3d effect changes the Spot Color Text into CMYK text, and its now useless to me, unless I delete the effect again.
    So my question is, how can I make a perspective transformation with my text, without losing my Spot Colors?
    Thanks a lot
    cynocephalus
    Adolf Witzeling replied 19 years, 9 months ago 3 Members · 2 Replies
  • Vincent Rosati
    December 6, 2006 at 5:58 pm
    Could you Expand (Object/Expand) the object than reapply your colors?
  • Adolf Witzeling
    December 7, 2006 at 5:30 pm
    after you create the 3d object, go to the Menue bar and choose , that’ll break your object in selectable pieces, that you can colorize with your desired spot color. Hope that helps.
    Adi
