Activity Forums Adobe Illustrator Illustrator CS2 Opacity Mask Woes
  • Illustrator CS2 Opacity Mask Woes
    Posted by Chris Kay on June 3, 2006 at 1:35 am
    Hi All,
    I’m currently working on a project in Illustrator CS2 where I require an object to fade out to complete transparency.
    I have followed the instructions on how to do this from the help file and it’s pretty much worked… EXCEPT for the fact that it doesn’t fade out to 100% transparency.
    If white in the gradient mask is 100% visible and black is 100% transparent, it appears a though black for me is only going to 90% transparency.
    I can’t get a perfect fade out like I can in Photoshop.
    Has anyone experienced this? Is there something I
    Mike Gondek replied 20 years, 3 months ago 2 Members · 1 Reply
  • Mike Gondek
    June 5, 2006 at 8:41 pm
    You need to edit your gradient that you are using for the mask. If you use a default linear gradient it is 100% on on end 0% on the other. Go to the gradient palette and slide black gradient slider over to about 90%. Another method you may like the results is switching the color of the black gradietn swatch to CMYK, and adding 50% or more cyan.
    You will want to do some test prints if this is going to print, as a 5% dot may hold up differetnly on differetn pritning presses/calibrations. If you are doing video, taht yuor final results will be easier to judge directly on screen.
