Activity › Forums › Adobe After Effects › illustrator CS2 artboard cropping problem
  • illustrator CS2 artboard cropping problem
    Posted by Matt Stalker on June 9, 2006 at 5:54 pm
    Normally, by default I always make my illustrator files 720×540 for broadcast work, and if my layers end up being much larger than that I’m usually bringing artwork into AE7 at “layer size” anyway. It was never a problem to bring in layers larger than the artboard size. Until now. Illustrator CS2 is cropping the display of the “oversized” layer in AE7 to the artboard size, even though it is properly recognizing the size of the layer as being “oversized”. I noticed some older posts reporting the same problem so I called Adobe. The boys at Adobe Tech Support tell me it’s just this way now…Obviously a workaround is to simply increase the artboard size, or shrink the vector graphics. But can I not work the way I used to, or is there something simple happening that I’m missing? It’s an extra step to open stuff in my vector graphics library and have to guess at how big to resize my artboards…
    Any thoughts appreciated,
    Matt
    Matt Stalker
    Center City Film & Video
    mstalker@ccfv.com
    Bret Williams replied 20 years, 3 months ago 4 Members · 4 Replies
  • Jason Linn
    June 9, 2006 at 8:11 pm
    try 720×480 if it’s NTSC?
  • Jason Linn
    June 9, 2006 at 8:13 pm
    or just make sure your res. is the same as your comp.
  • Sam Moulton
    June 9, 2006 at 10:20 pm
    if your illustrator file is d1 size ae will probably think it’s rectangular pixels when it’s not. I’d make crop marks or import as a comp with cropped layers which is my favorite and then adjust the comp size before I do any animating.
  • Bret Williams
    June 9, 2006 at 10:42 pm
    Or 720×534 for DV sq pixels.
