Activity › Forums › Adobe Illustrator › illustrator CS error opening file
  • illustrator CS error opening file
    Posted by Matt Stalker on November 2, 2005 at 6:49 pm
    Got a .ai file from a client that gives me an error when trying to open in Illustrator CS:
    “Acrobat PDF File Format is having difficulties. Expected a non-negative integer.”
    I’ve asked the client to resave and resend the file, but I’m wondering if anyone out there knows what this error is indicating, and if there is something in the way the client saved the file that may have caused it. Time is tight, and if the file comes back to me with the same problem again, I’ll need a solution.
    Thank you very much for your help,
    Matt
    Matt Stalker
    Center City Film & Video
    mstalker@ccfv.com
    Matt Stalker replied 20 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
