Activity Forums Adobe Illustrator Illustrator: BIG FILE and SLOW working…
  • Illustrator: BIG FILE and SLOW working…
    Posted by Idiosynn Nele on May 30, 2010 at 1:35 pm
    Hi there,
    I’m working for a textilecompany and I need to make a file 4000 x 4000 mm where I design sheets (linen)
    1400 x 2000 mm for the sheet where I need to make a pattern by copy pasting it. The problem is: the original vector is a .ai file about 3mb.
    When I copy paste it for about 20 times the file becomes big (about 50mb. what is weird because there are only vectors included).
    Illustrator gives me at one moment a dialogbox where it says there is not enough memory to do this action. (I have a Mac Pro Quadcore with 4 Gb RAM… which is enough.. certainly for files of 40 mb..) I really dont understand why it becomes so slow to work…
    At one moment is just turns my file into contourlines.. and I cant fix it anymore…
    Anyone who had the same problem? How did you fix it?
    thank you!!
    Mike Gondek replied 15 years, 12 months ago 3 Members · 2 Replies
  • Vincent Rosati
    May 30, 2010 at 6:53 pm
    Maybe try turning off PDF compatibility in Edit/Preferences.
    You might have to restart for this to take effect, unsure.
    Maybe set a low resolution in Effect/Document Raster Effects Settings, in the documents that you are using.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Mike Gondek
    June 14, 2010 at 12:42 pm
    Try making a pattern swatch, rather than copying and pasting your pattern tile, your file will become much slimmer/quicker.
    You basically draw a rectangle with no file or stroke, and send that to back. Then select your rectangle and artwork and drag this to your swatches to make a pattern swatch.
