Activity › Forums › Adobe Illustrator › Illustrator banner size
  • Illustrator banner size
    Posted by Maria Ceraulo on August 26, 2014 at 11:06 am
    Hi everybody,
    this is my first post here in Creative Cow.
    I ve just one simple question..
    I ve to do a banner high 2 meter and large 75 cm.
    Which size I ve to set up in illustrator?
    Thank you
    Mary
    Jonathan Ziegler replied 12 years, 1 month ago 2 Members · 1 Reply
  • Jonathan Ziegler
    August 29, 2014 at 12:09 am
    Probably 200cm x 75cm?
    If you’re printing it yourself, you may need to check with the RIP for your printer.
    If you’re sending out to be printed, ask the printers what settings they require for Illustrator files. May also need to rasterize so ask what settings (ie: dots per cm) they require so you can do it all in one step when you rasterize.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
