Activity Forums Adobe Illustrator Illustrator and pro animator help
  • Illustrator and pro animator help
    Posted by David Gilhooly on May 8, 2006 at 7:52 pm
    I am using AI CS2 with pro animator 3 i want to get a drawing from AI in to Pro animator. However, every time i try to open a AI file in to Pro it says Not enough memory. can any one help?
    Also i know that i have to use paths to do this what is the best way to draw and close the path in AI.
    Fabiano Peres replied 20 years, 4 months ago 2 Members · 1 Reply
  • Fabiano Peres
    May 9, 2006 at 12:48 pm
    Try to make small drawings, if it’s goig to be 3D you’ll be abl to zoom in as much as you wish without loosing quality, olny use simple colors no textures…. texturing you will do in pro animator…
    The best tool for creating good shapes is the pen tool. to close a path, just click over the first point you have created.
    If you have text on you project after finish it, right click it and choose “create outlines”…
    big hugs from Brazil
