Activity Forums Maxon Cinema 4D Illustrator 8 file won’t open in C4D
  • Illustrator 8 file won’t open in C4D
    Posted by Ray Lux on June 23, 2014 at 7:56 pm
    I saved my illustrator file which is made up of basic shape paths as Illustrator 8. When I try to import it into Cinema 4D it says “Unknown File Format.” Everything online says this should work. I can’t even find anyone else with the same problem.
    Any ideas?
    Ray Lux replied 12 years, 2 months ago 3 Members · 5 Replies
  • Brian Jones
    June 24, 2014 at 6:32 pm
    correct, it should work. Perhaps the file is corrupt. Can you post it?
  • Ray Lux
    June 25, 2014 at 12:41 am
    Unfortunately I have tried multiple files.. one of which was just a single box… still unrecognized file format.
    Everything is fully updated.
    I think something might be wrong with the program itself.
  • Adam Trachtenberg
    June 25, 2014 at 4:36 pm
    If you post a file we’ll be able to tell you if it’s a problem with your Cinema or a problem with Illustrator.
  • Ray Lux
    June 25, 2014 at 10:49 pm
    I had a friend test the illustrator file and it worked on his machine.
    I just reinstalled C4D and it still doesn’t work…
  • Ray Lux
    June 25, 2014 at 10:52 pm
    Problem solved!
    Turns out when I save the illustrator and I set the Preview Mode to NONE it will open. It doesn’t explain why it opened without fail on my friends machine but I am happy for now.
