Activity Forums Maxon Cinema 4D Illustrator 10 & paths
  • Illustrator 10 & paths
    Posted by Christian Remde on March 2, 2007 at 2:25 pm
    I’m using C4D 10 and Illustrator CS2…when I bring text made in illustrator, it groups each letter path into a null object. I tried dragging the null object (with all the paths grouped into it) into an Extrude NURBS object, but I think it’s trying to extrude the null object and not the paths that are inside it.
    I guess my question is, do I have to apply an Extrude NURBS object to each path individually, or is there a way to do it all at once?
    Christian
    Christian Remde
    https://www.christianremde.com
    Christian Remde replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mikeh64
    March 2, 2007 at 2:31 pm
    there is a checkbox in the extrude nurbs called “hierarchical”
    this will extrude all the paths under the null
  • Christian Remde
    March 2, 2007 at 2:34 pm
    Thank you! Man, that was driving me crazy…
    Christian Remde
