Activity Forums Adobe After Effects Illustrator 10 Pathfinder mystery resolved
  • Illustrator 10 Pathfinder mystery resolved
    Posted by Jean Hauptman on April 3, 2005 at 2:23 pm
    I don’t know if you guys use Illustrator Pathfinder in animation projects. I use Shapemodes
    for 3-d elements in Zaxworks and for vector shapes in AE.
    A lot of animators were bummed out by Illustrator 10.0 It seemed like Shapemodes was
    not usable. Instead of joining layers into a single shape, it merely grouped 2 graphics.
    It turns out that there is a little button on the menu. To fake everyone out,
    the button is labeled “Expand.”
    You click on the Expand button, and everything joins into one shape like the good old days.
    Michael replied 21 years, 5 months ago 3 Members · 3 Replies
  • Scott Thomas
    April 4, 2005 at 3:12 am
    The idea is that the two grouped objects are still editable. In theory, you could not expand anything and then use the pull-down to expand everything as a last step. Until then, you can tweak to your heart’s content.
    I don’t use Illustrator in this way. Often I need that Pathfinder expanded “result” to cut something else out. I do a lot of logo design, but I’m probably not the most efficient Illustrator user as I am self taught and only crack the manual when I run into a roadblock.
  • Jean Hauptman
    April 4, 2005 at 4:09 am
    Yeah, it’s a beautiful program. Total Training illustrator shows amazing stuff you can do with it. I probably won’t have time till the next lifetime, though.
  • Michael
    April 7, 2005 at 2:04 am
    I have used Illustrator since version 4 on Windows (on floppies) ….and when my change from 8 to 10 happened…I was totally lost with pathfinder until the day I discovered the “new” expand button… I appreciate the ability to edit vectors (in a combined pathfinder boolean) but I miss the simplicity of the earlier versions…
    don’t get me started on the way they handle compound paths as layers now!….:)
    Michael
    (Pseudo-old school graphic guy)
