Activity Forums Adobe Premiere Pro Illustrations losing quality in PP
  • Illustrations losing quality in PP
    Posted by Jude Mclean on July 10, 2016 at 6:40 pm
    For some reason, particular graphics are losing quality in PP, especially blue hues or areas where drop shadows were applied, their original colour is disrupted around the edges mostly.
    Any ideas why this may be would appreciated, thanks.
    Jon Doughtie replied 10 years, 2 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    July 10, 2016 at 7:51 pm
    How about some system specs? Format specs? Sequence settings? Maybe some screenshots of the problem?
  • Jude Mclean
    July 10, 2016 at 8:25 pm
    Here my system specs:
    Here’s a screen shot of the loss of quality I’m observing:
    Here are my sequence settings:
    Here are my export settings:
  • Jon Doughtie
    July 11, 2016 at 1:00 pm
    One thing I observe is that although you are editing in SD, you are outputting HD. You are blowing up the resolution from 720×480 interlaced widescreen to 1280×720 progressive. That alone may account for the softness and slight imperfections you are noticing.
    Although rendering using “Maximum Render Quality” will help in your upscale, it will not produce miracles, I’m afraid. SD is still SD.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Jon Doughtie
    July 11, 2016 at 1:15 pm
    Oops – one correction. I zoomed in on your pixel aspect ratio for your project timeline. Although your timeline is 1280×720, you have set a pixel aspect ratio from NTSC SD widescreen. 1280×720 is natively widescreen.
    That pixel aspect ratio seting is likely distorting your pixels in your finished project, also creating the issues you are seeing.
    System:
    Win 7 64-bit
    32GB RAM
