Activity Forums Apple Final Cut Pro Legacy Illegal levels when down converting HD to SD
  • Illegal levels when down converting HD to SD
    Posted by Peter Wolsey on February 20, 2014 at 12:48 pm
    Hi there
    I know this is probably a Kona LHi issue, but since it’s connected with FCP then I thought I’d give this forum a whirl.
    We’re editing on FCP7 and AJA Kona-LHi card on well spec’d Mac.
    We film and edit entirely in HD, but need to supply our UK broadcaster with Digibeta TX tapes for PAL SD broadcast. We’re very careful to ensure that the RGB levels leaving FCP are legal.
    We use the Kona card to down convert the HD timeline to SD suitable for the Digibeta deck, but we’ve had our tapes fail the Tech Review process because of illegal levels. When I replay our digibeta copies I find that the recorded levels are indeed often way over 100% on the waveform monitor, and also fall way below O% . This is despite the FCP waveform monitor says the output leaving FCP is within legal levels.
    I’ve tried every conceivable output setting on the AJA control panel, but with no luck.
    Any ideas?
    Pete
    Peter Wolsey replied 12 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
