Activity Forums Blackmagic Design iLife 09 GarageBand will not work with Decklink Driver?
  • iLife 09 GarageBand will not work with Decklink Driver?
    Posted by Sean Lander on February 4, 2009 at 12:22 pm
    Just got a copy of iLife 09 but have found that GarageBand will not work properly at all if you have the Decklink selected as the sound output device. Is there a solution to this? Do I just reinstall the drivers perhaps?
    Ara Keshishian replied 16 years, 8 months ago 2 Members · 2 Replies
  • Sean Lander
    February 4, 2009 at 12:39 pm
    To answer my own question it would seem that re-installing the drivers does work but you may need to manually select the decklink driver in GarageBand preference for output.
    R E D N A I L – M E D I A
    web: http://www.rednail.com.au
    email: rednail@me.com
  • Ara Keshishian
    November 24, 2009 at 7:17 am
    Hi I can get my Decklink Extreme 3 to work with Garageband, did you figure it out? I tried switching output in GB to Decklink with no change….many thanks
