Activity › Forums › Maxon Cinema 4D › IK Rig Problem
  • IK Rig Problem
    Posted by Seun Jubril on November 1, 2019 at 6:26 pm
    Hello everyone,
    So I’m working on a a project where I have to rig the surface going into some kind of “scrunch mode”. It seemed logical to use IK for the rig so everything moves together. The problem I’m having is that the bend is happening in the wrong direction. I see that the issue is coming from position of the first and last joint, their starting position naturally creates a bend in the wrong direction which causes to the IK to bend in the wrong direction. I can’t seem to figure out a work around for this. If i switch the pole vectors, things don’t move like their supposed to, and I can’t find a solution for animating the pole vector so it doesn’t pop into place. I’ve also tried experiment with other methods other than IK, but the pieces don’t track together when they’re animated separately. I’m really lost on this one, so I’d appreciate some insight/help!
    Here’s Google Drive link to a test file: https://drive.google.com/file/d/1VfDq-591zFh42p39Rb_mAQIB8OqeJfle/view?usp=sharing
    Seun
    Brian Jones replied 6 years, 10 months ago 2 Members · 1 Reply
  • Brian Jones
    November 2, 2019 at 8:41 pm
    Don’t do enough IK to know exactly why but I added a Pole which flipped the rig so I Twisted 180 in the pole control, moved it in the correct place. It was still ‘crunching’ in the wrong direction so I changed the Axis in all the joints to Y (and hit Align). Now it’s moving in the right direction I think.
    Hmmm maybe only Joint and Joint.1 are necessary to Align in Y but all 3 is a slight alignment change that I think is better.
    13862_ikrigtest2.c4d.zip
