Activity Forums Maxon Cinema 4D IK Chain bends the wrong way.
  • Adam Trachtenberg
    July 29, 2015 at 5:25 pm
    Did you try adding a pole vector?
  • Daniel Amidirad
    July 29, 2015 at 5:26 pm
    Yes, I did.
  • Adam Trachtenberg
    July 29, 2015 at 5:35 pm
    Well … there are no IK tags in your file? As a rule you want to put a slight rotation in the joint before you create the IK. That gives the tag a hint as to which way you want the joint to bend. The pole vector will provide an even better hint and allow you to rotate the chain.
    You might need to rotate your joints more than the very slight amount you have now.
  • Daniel Amidirad
    July 29, 2015 at 5:36 pm
    I’ve tried rotating by 10 degrees, 20 degrees and even 30 but still to no avail. I took them out of the file so people could see for their own, try it out.
  • Daniel Amidirad
    July 29, 2015 at 5:37 pm
    I’ve fixed a part.
