Activity Forums Adobe After Effects Iff sequence problem
  • Iff sequence problem
    Posted by John Titor on February 23, 2014 at 10:39 pm
    Hi, I have an .iff image which I want to apply directional blur to and when I render it out as an .iff sequence the sequence itself is shorter than the original duration of the image in the AE project. It’s like it’s moving at a slightly faster frame rate as when I match it up it goes out of sync at a later point in the timeline. I’ve checked that the frame rate matches the frame rate in the comp settings. Is there any way to solve this?
    John Titor replied 12 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
