Activity Forums Adobe After Effects If/Else Statement + Source Text + Position Coordinates
  • If/Else Statement + Source Text + Position Coordinates
    Posted by Paul Connors on September 28, 2016 at 3:04 pm
    Hi Guys,
    I’m trying to write an expression to set the exact X,Y coordinates of a layer based on the Source Text of another layer.
    • Text layer named “SETUP”
    • Solid named: “S1”
    When the source text for “SETUP” says: “Target1” I’d like the position of S1 to be at 760,340.
    Here is the expression I have on the position of S1:
    input = thisComp.layer("SETUP").text.sourceText;
    xPos = if( (input == "Target1") ) 760 else 0;
    yPos = if( (input == "Target1") ) 340 else 0;
    [xPos, yPos]
    In my mind that should be working. But it’s not. Haha. I’m getting an error that says: “Error at line 2 in property ‘Position’ of layer 3 (‘S1’) in comp ‘Positions Test_001’. Illegal use of reserved word., an expression was disabled as a result of an error.
    Anyone got any ideas? It’d be greatly appreciated. Thank you!!!
    Paul Connors replied 9 years, 10 months ago 2 Members · 2 Replies
  • Walter Soyka
    September 28, 2016 at 6:57 pm
    You cannot use an if statement to assign a value like this. If controls flow and does not return a value.
    You have two options. One is to use if properly:
    if (input == "Target1") xPos = 760 else xPos = 0;
    if (input == "Target1") yPos = 340 else yPos = 0;
    [xPos, yPos]
    The other is to use the ternary conditional operator, which looks like this:
    statementForEvaluation ? valueIfTrue : valueIfFalse;
    and returns one of the values according to the evaluation of the statement:
    xPos = (input == "Target1") ? 760 : 0;
    yPos = (input == "Target1") ? 340 : 0;
    [xPos, yPos]
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Paul Connors
    November 1, 2016 at 3:32 pm
    Hi Walter. I’m really sorry for the late reply. Thanks very much for the help with this!
