Activity Forums Adobe After Effects Expressions if/else – position
  • if/else – position
    Posted by Michał Chraper on March 27, 2018 at 8:56 am
    I’m trying to write expression that moves object as long as “speed” parameter is not equal to 0. I have no alert from AE about that code but it doesn’t do the job, nothing happens…
    speed = effect("Slider Control")("Slider");
    x = transform.position[0];
    y = transform.position[1];
    if (speed == 0) {[x, y]}
    else {[x + time*speed, y]}
    Michał Chraper replied 8 years, 5 months ago 2 Members · 3 Replies
  • Dan Ebberts
    March 27, 2018 at 4:31 pm
    Animating speed in AE is not simple. This may be helpful:
    https://www.motionscript.com/articles/speed-control.html
    Dan
  • Michał Chraper
    March 28, 2018 at 9:31 am
    Thanks for respond Dan. Reading the article You quoted I understood where is the problem in my expression. I didn’t know that I can’t use “speed” word as variable name. Since I change it to “spd” shortcut expression started to work.
    Indeed it’s a bit complicated to control acceleration and deceleration but until you want to control constant speed, e.g. by slider control, it’s easy as my expression 😉
  • Michał Chraper
    March 28, 2018 at 9:36 am
    So, with little modification, working code looks like that…
    spd = effect("speed")("Slider");
    x = value[0];
    y = value[1];
    if (spd == 0) {[x, y]}
    else {[x + time*spd, y]}
