Activity Forums Adobe After Effects Expressions if/else exists expression
  • if/else exists expression
    Posted by Scott Mcgee on October 12, 2017 at 10:19 am
    for (var i = 1; i <= myComp.numLayers; i++){
    var myComp = app.project.activeItem;
    var nNum = myComp.layer(i).effect(“Name”)(“Slider”).value;
    var name = myObject[nNum].name;
    myComp.layer(i).name = name;
    I’m having a little problem with my script.
    My name layers will never be the same, but the ones I want to effect will all have the slider “Name”…Again value will differ. The number is for my JSON reference…
    Now…The above expression in my script works fine, if I don’t have any other layers that have no slider or a different slider.
    I don’t have a way to reference the content of the slider, so I need it to say “if I exist change me else continue” I’ve tried a few things with no success.
    I’m sure I’ve read someone with a similar situation, but I’ve read about 50 different forums and can’t find anything. Any ideas?
    Scott Mcgee replied 8 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 12, 2017 at 1:03 pm
    One way might be to use try/catch:
    try{
    // try to do something here
    }catch(err){
    continue; // end up here if it don't work
    Dan
  • Scott Mcgee
    October 12, 2017 at 1:30 pm
    I am a moron….
    I even tried a try/catch, but did it every wrong way possible, even when you posted that I did it wrong initially again and realised I have to put it in the loop for it too work, because I want to reference 4 categories I’ve been trying to put the try outside of it.
    That is working sport on now.
    Thank you for putting that, I would have gone around in circles otherwise.
    try{
    }catch(err){
    continue;
    try{
    var lNum = myComp.layer(i).effect(“Location”)(“Slider”).value;
    var location = myObject[lNum].location;
    myComp.layer(i).name = location;
    }catch(err){
    continue;
    Unless you can think of a tidier way for this…I only have to do it 4 times and it’s only a find and replace. Last year I typed 480 text layers out, I’m doing it again this year and giving myself RSI hahahaha.
    Appreciate that.
