Activity Forums Adobe After Effects Expressions If/else array problem
  • If/else array problem
    Posted by Aniello Ferrone on December 8, 2019 at 12:20 pm
    Hi Masters,
    I can’t understand why this array is not working. It’s always on the “else” value.
    I tried to be very specific but it seems to go in contrast.
    Can you help me?
    Thank you so much
    r1 = comp("Rigo 1").layer("Text 01").text.sourceText;
    r2 = comp("Rigo 2").layer("Text 01").text.sourceText;
    r3 = comp("Rigo 3").layer("Text 01").text.sourceText;
    r4 = comp("Rigo 4").layer("Text 01").text.sourceText;
    r5 = comp("Rigo 5").layer("Text 01").text.sourceText;
    if ((r1 >= 0) && (r2 == 0) && (r3 != 0) && (r4 != 0) && (r5 >= 0 )) {
    [0,-120.5];
    } else if ((r1 >= 0) && (r2 == 0) && (r3 == 0) && (r4 != 0) && (r5 >= 0)) {
    [0,-46.5];
    } else if ((r1 >= 0) && (r2 != 0) && (r3 != 0) && (r4 == 0) && (r5 >= 0)) {
    [0,-260.5];
    } else if ((r1 >= 0) && (r2 != 0) && (r3 == 0) && (r4 == 0) && (r5 >= 0)) {
    [0,-331.5];
    } else if ((r1 >= 0) && (r2 != 0) && (r3 != 0) && (r4 != 0) && (r5 >= 0)) {
    [0,188.5];
    } else if ((r1 >= 0) && (r2 == 0) && (r3 != 0) && (r4 == 0) && (r5 >= 0)) {
    [0,188.5];
    } else { [0,-188.5]; }
    Aniello Ferrone
    Viral Video Editor
    http://www.fanpage.it
    Aniello Ferrone replied 6 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 8, 2019 at 3:36 pm
    Try converting each of your r1 thru r5 variables to numbers, like this:
    r1 = parseInt(comp(“Rigo 1”).layer(“Text 01”).text.sourceText.value,10);
    Dan
  • Aniello Ferrone
    December 9, 2019 at 4:13 pm
    Thank you Dan,
    It doesn’t seems to fix it, I’m starting to think that there is something wrong with all that conditions, for example, this is working perfectly
    Thank you so much
    Aniello
    //Se -||
    if ((r1 == 0) && (r2 != 0) && (r3 != 0)) {
    [0,-137];
    //Se --|
    } else if ((r1 == 0) && (r2 == 0) && (r3 != 0)) {
    [0,-30];
    //Se ||-
    } else if ((r1 != 0) && (r2 != 0) && (r3 == 0)) {
    [0,-339];
    //Se |--
    } else if ((r1 != 0) && (r2 == 0) && (r3 == 0)) {
    [0,-433];
    //Se |||, -|-, |-|
    } else { [0,-232]; }
    Aniello Ferrone
    Viral Video Editor
