if you’re a one man band, is there any advantage to using Prelude over Premiere for logging footage???
I’ve read in many places that Prelude was essentially designed as a collaboration tool for multiple editors working on the same project and as a simple rough cutting program to allow someone to put together a quick rough cut for an editor to later refine in Premiere. I also read that the program is not really necessary for if you’re a one man band setup doing all the editing yourself. Is this still the case?
I’m about to start cutting a long format documentary with an enormous amount of footage, over 100 clips. To log all this media, I’m wondering whether I should be using Premiere or would I be better served using Prelude? The media in question is already on the computer but needs to be sifted through and scenes annotated. Would there by any advantage to using Prelude over Premiere when it comes to simply logging (not sharing, transcoding, or importing).
