Activity Forums Apple Final Cut Pro if you understand colour – why?
  • if you understand colour – why?
    Posted by Wayne Garton on May 14, 2012 at 8:26 am
    We record a weekly show. It’s always a speaker in front of lights (parkans). On the flesh line with the scopes in FCPX, the face is the correct colour, but his dark grey suit is showing brown. I haven’t recorded many programmes yet with the EX1 cameras we have, (since we have only just changed from SD to recording in HD), so there is still a bit to learn on the camera score.
    But the thing I don’t know is how to colour correct in FCP so that the the face doesn’t look un-natural yet the suit is closer to the the real colour, because if I lower the reds in the mid range or blacks, it corrects the suit but the face is way off!
    Maybe we should just concentrate on the lights instead.
    Perhaps someone with a lot more experience can guide me in this one.
    Cheers
    Wayne
    New Zealand
    Wayne Garton replied 14 years, 4 months ago 6 Members · 6 Replies
  • Andy Mees
    May 14, 2012 at 9:24 am
    Hi Wayne
    You can use a Shape or Color mask to isolate just specific areas or colors within the image you want to correct.
    https://help.apple.com/finalcutpro/mac/10.0/#verca9e937d
    Cheers
    Andy
  • Geoff Addis
    May 14, 2012 at 10:50 am
    The EX1 sensor is sensitive to the low infra-red region of the colour spectrum and you need to use an appropriate filter in front of the lens. Both B+W and Schneider make such filters. Tungsten lighting is usually quite rich in infra-red!
    Hope this helps,
    Geoff
  • Tom Wolsky
    May 14, 2012 at 1:04 pm
    Hi Andy, Nice to see you here.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
  • Bret Williams
    May 14, 2012 at 2:45 pm
    Lower the reds in the blacks, move the mid control directly above the black control, and raise it, bringing back the same amount of red back into the mids. If that doesn’t work you have to go Andy’s route.
  • Jeremy Garchow
    May 14, 2012 at 4:32 pm
    [Geoff Addis] “The EX1 sensor is sensitive to the low infra-red region of the colour spectrum and you need to use an appropriate filter in front of the lens. Both B+W and Schneider make such filters. Tungsten lighting is usually quite rich in infra-red!”
    Nailed it.
  • Wayne Garton
    May 14, 2012 at 8:47 pm
    Thanks so much for sharing your wealth of experience. I will try all of your suggestions.
    Cheers
    Wayne
    New Zealand
