If you are interested in doing Flash
I found an excellent and inexpensive ($49) program called “Flash Video MX.” When doing conversions it gives you a lot of control over the picture and writes the HTML file. (If you have done HTML you know that is worth $49.) It does batch encoding and has a simple slider to downsize a file and the quality is very good. The program is at:
https://www.flash-video-mx.com/Here are some samples:
Smaller file:
https://link6.streamhoster.com/?u=idalexed&p=%2FNineveh%2Ftr3-368a.html&odaid=2559&prog=trueHere is a bigger flash file:
https://link6.streamhoster.com/?u=idalexed&p=%2FNineveh%2Ftr3-608a.html&odaid=2559&prog=trueJerryW
