Activity Forums DSLR Video If video on DSLR uses only part of sensor, how come I still get great DOF?
  • If video on DSLR uses only part of sensor, how come I still get great DOF?
    Posted by Vic Noseworthy on October 23, 2012 at 11:41 am
    Hi folks,
    One thing I’ve wondered about is this:
    From what I understand, when I shoot video using my Canon T3i, it uses only 1080 x 1920 of the (significantly!) higher resolution sensor. Yet, it’s this larger sensor that gives me the bokeh I so love. Seems to be a conflict in the logic here. Can anyone explain how I get the bokeh afforded by a large sensor if only a small piece of the sensor is being used?
    Thanks so much!
    Vic
    Pete Burger replied 13 years, 10 months ago 2 Members · 3 Replies
  • Pete Burger
    October 23, 2012 at 12:31 pm
    In 1080p and 720p your DSLR uses the full sensor but reduces the framesize through line-skipping. Only when you’re shooting in SD, the center part of the sensor is used. This won’t reduce DOF either because it’s like extracting just a portion of the full-frame which still has the “full” shallow DOF.
    “Tragedy is a close-up; comedy, a long shot.” – Buster Keaton
    Me on Twitter (english/german)
    https://twitter.com/FastFoodVideo
  • Vic Noseworthy
    October 23, 2012 at 6:20 pm
    Hmmm… interesting. Thanks, Peter. So, then, does this mean it also uses only a segment of each line, too? (Otherwise, wouldn’t the ratio be off?)
    Thanks again,
    Vic
  • Pete Burger
    October 23, 2012 at 7:36 pm
    I’d say the camera crops the picture above and below.
