Activity Forums VEGAS Pro if trans-coding before editing – color correct before transcoding or after?
  • if trans-coding before editing – color correct before transcoding or after?
    Posted by Don Cobble on April 30, 2017 at 2:50 am
    I have to trans-code most of the footage i receive to make it cross platform.
    It come as GV HQX 1080 59.94 10bit I am trans-coding to DNxHD 1080 29.97P
    After tons of render test for both speed / size and quality, I landed on DNxHD to be the most versatile for the different editor MAC & PCs.
    The question is a “Quality for editing Question?
    I use my Vegas to trans-code, should I do my basic color matching before or after trans- coding
    Thank You
    Don
    Aaron Star replied 9 years, 4 months ago 3 Members · 3 Replies
  • Francois Pénzes
    April 30, 2017 at 3:25 am
    Hi Don
    I would do it before. There is always a certain amount of loss every time your file is processed, regardless.
    Way better to start off with as decent of a picture as possible.
    Remember that you will be going from 59.94 down to 29.97.
    You can always do some fine tuning afterwards.
    Cheers !
    PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    \’\’When the cutting stops, the editing begins…\’\’
  • Don Cobble
    April 30, 2017 at 5:23 pm
    Thank You Francois! will do!
  • Aaron Star
    April 30, 2017 at 6:29 pm
    I would do some gradient tests when using vegas to process to DNxHR from a 10-bit source. I might be wrong, but I think there is a problem with quicktime not passing the 10bit info through the workflow. Regardless you need to do your processing in 32-bit video levels.
    Resolve, or FFMPEG transcode might be better.
