Activity › Forums › Adobe After Effects Expressions › If statements holding values
Dan Ebberts
January 8, 2016 at 11:16 amGood point. I guess that would be the case as long as the flip is instantaneous and there’s no hysteresis (up and down thresholds are the same).
Dan
Ymri Scheiner
January 9, 2016 at 5:03 pmThank you a lot ! I’ve tried and it works ! Just to know, what does (n%2) means ?
Dan Ebberts
January 9, 2016 at 6:45 pm% is the JavaScript modulus operator, which gives you the remainder of a division operation, so (n%2) will be true if n is an odd number, false if it is an even number (assuming n is an integer, as it is in this case).
Dan
Ymri Scheiner
January 10, 2016 at 3:45 pmOh ok but shouldn’t you put the ==0, or does it recognize you mean if this equals 0 when you put nohting ?
Dan Ebberts
January 10, 2016 at 5:21 pm(n%2 != 0) would give you the same result, but anything that’s not zero gets interpreted as true.
Dan
