If redshift motion vector pass or motion blur is enabled renders not the same
I’ve modelled a shark and rigged it with the cinema 4d character feature which made it easier for me to make the shark move it’s fins and tail without keyframes. Then I used the spline tag on the joint master controller to animate the shark on a spline. Everything seems to be moving along in the viewport and when I render without motion blur or the motion vector pass but when I enable motion blur, the shark moves along the spline but shark does not move the tail or find, it’s just stiff
