Activity Forums VEGAS Pro If one does use AE, what is the best render option?
  • If one does use AE, what is the best render option?
    Posted by Ron Whitaker on January 22, 2014 at 9:47 pm
    If I do editing within Sony Vegas Pro, and then want to do post within AE, what is the best render options (codec) to render to with the least amount of compression so that quality isn’t lost on the video?
    Thanks.
    Steve Rhoden replied 12 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    January 22, 2014 at 11:58 pm
    The render option i always use is Quicktime.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Ron Whitaker
    January 23, 2014 at 12:10 am
    Thanks. Does Quicktime not do a lot of compression when rendered?
  • Norman Black
    January 23, 2014 at 1:21 am
    [Ron Whitaker] “Does Quicktime not do a lot of compression when rendered?”
    Quicktime what? Quicktime is a file format that can contain many types of encoded video streams. So unless you talk about a specific video codec then one cannot answer that question.
    Codecs might be AVC, mpeg-2, DNxHD.
    DNxHD would give you the least compressions and biggest files. For that you would have to download the free DNxHD codec from Avid.
    https://avid.force.com/pkb/articles/en_US/download/Avid-Codecs-LE-2-3-9
    In another thread you asked about Cineform. This would be similar to DNxHD.
    A high bitrate AVC/H.264 stream is another high quality option.
  • Ron Whitaker
    January 23, 2014 at 3:36 am
    Actually, I figured it out!
    I checked within the Quicktime option within Render As and there are A LOT of codecs available.
    Some time ago I downloaded the Avid DNxHD codec, so that’s the one I’d probably use.
    Thanks.
  • Simon Laidlaw
    January 23, 2014 at 9:21 am
    For short animations going from AE into Vegas I tend to use the ‘Animation’ codec and for more video based content QT I aslo use Avid DNXHD.
    Also for stand alone AE projects the QT .h264 codec will work fine for YouTube/ Vimeo quality output. Yes it compresses the content but It’s going to get compressed by YouTube anyway.
    http://www.cutmustard.tv
  • Steve Rhoden
    January 23, 2014 at 10:52 am
    I recommend and use Quicktime because its globally compatible,
    easy on the system, doesn’t output massive file sizes and outputs
    pristine quality despite compression (compression which your eyes
    cant even notice anyway
    So my three choices from AE are always Photo-jpeg, Animation or png.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Steve Rhoden
    February 10, 2014 at 11:01 pm
    PNG for alpha output!
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
