Activity Forums Media 100 If Media 100 only had the “snap-to” function.
  • If Media 100 only had the “snap-to” function.
    Posted by Jim Wigler on October 28, 2005 at 3:56 pm
    Occasionally, in the flurry of editing, I inadvertently leave a BLANK FRAME on the timeline. None of the “close gaps” functions seem to work over multiple clips. Is this just me or am I missing something?
    J m Wigler
    Jim Wigler replied 20 years, 10 months ago 2 Members · 2 Replies
  • Bernie Huth
    October 29, 2005 at 4:55 pm
    Under the Tools Menu there is:
    Snap to other clips with a keyboard shortcut of Uppercase-Command-1.
    For removing gaps there are three possibilities under the Program Menu:
    Remove All Gaps – Command-K
    Remove Gaps to End – Command-J
    Remove Gaps in Range – Command-R
    HTH
    Bernie Huth
    Digital Media Specialist
    San Jose, CA
  • Jim Wigler
    October 29, 2005 at 7:44 pm
    Thank you, Bernie!
    I’ll try and get it to work correctly. But with multiple clips, all I get is the error alert.
