If I want to have 60fps footage to match with 1080 24fps, should i go 720 60p or 180 60i?
For my latest project, I’m using an HMC-150. I want to shoot some things in 60fps so I can do slo-mo on them. Most of the footage is 1080 24fps.
What is the best way to do that? Should I use the 1080 60i or the 720 60p? The film will, ideally, get on TV if that helps solve things.
