Activity › Forums › Adobe Premiere Pro › If I record onto a minidisk at the same time as a camcorder can I sync it later?
  • If I record onto a minidisk at the same time as a camcorder can I sync it later?
    Posted by Dougie Campbell on June 11, 2008 at 9:41 pm
    Just wondering If I record onto a minidisk at the same time as a camcorder can I sync it later in Premiere Pro CS3.It will surely stay in time all the way through as it’s both digital-yes or no?
    Vince Becquiot replied 18 years, 3 months ago 4 Members · 3 Replies
  • Ann Bens
    June 11, 2008 at 10:19 pm
    Yes.
    To get it synced in Premiere make a short loud sound clearly to be heard on the minidisk and camera. Let both run the whole time during taping do not use the stop button.
  • Steven L. gotz
    June 11, 2008 at 10:48 pm
    You may find a little drift, but that should be correctable with a minor adjustment every few minutes or so.
    Steven
    https://www.stevengotz.com
  • Vince Becquiot
    June 12, 2008 at 3:53 pm
    What they are saying though is that it might quickly turn into a pain in the %@# 🙂
    Especially on long shoots.
    You may have another reason for doing it, but a good reason would involve a high end recorder, with high end preamps, which would be better than those of most comcorder, and with more inputs.
    Unless you have a way sync the two(blackburst, timecode…), you will probably see a drift, so be prepared to spend some extra time on it.
    Vince
