Activity › Forums › Maxon Cinema 4D › if I align an object on spline and clone it then using random effector and adjusting “time” it takes it off the spline
  • if I align an object on spline and clone it then using random effector and adjusting “time” it takes it off the spline
    Posted by Chad Demoss on January 15, 2019 at 8:29 pm
    I have an object with an “align to spline” tag and I am animating the tag position from 0 to 100. everything works fine except when I try to adjust the “time” in the random (or step) modifier so that all the clones are not starting and stopping at the same time. when I adjust time to anything but 0 the object doesn’t animate along the spline anymore.
    Chad Demoss replied 7 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Brian Jones
    January 15, 2019 at 8:41 pm
    can you post the file?
  • Chad Demoss
    January 15, 2019 at 8:43 pm
    I’m not sure how to upload the file when I click on the little icon that says “file upload” it looks like it tries to create a whole new post
  • Brian Jones
    January 15, 2019 at 8:50 pm
    it doesn’t really that takes you through an upload process which gives you a link you can copy/paste back into the original but there is an easier way, just drag and drop the file into the message window and it does it automatically.
  • Chad Demoss
    January 15, 2019 at 8:52 pm
  • Chad Demoss
    January 15, 2019 at 9:45 pm
    ok that is easy.
  • Brian Jones
    January 16, 2019 at 4:13 am
    what’s the long term goal? to have more than the one clone I would guess, going off in a a wave or randomly? But aligning to spline and cloning won’t give you that, I think, since all the cloned align to spline tags would all point to the original spline not the cloned instances you are (I think) hoping for.
  • Chad Demoss
    January 16, 2019 at 11:27 pm
    I just want a bunch of lines to draw on like trim paths in illustrator. but I dont want them to all start and end at the same time. I think my #1 issue in cinema 4d is off setting the timing of clones. If i do something real basic I can offset the time in random and it works no problem. if I start adding stuff it never seems to work.
