Activity Forums Adobe After Effects Expressions If/else transition between two conditions?
  • If/else transition between two conditions?
    Posted by Las Wen on September 16, 2021 at 5:59 pm
    Hey… im guessing if there is a way to have an kind of animation/transition between two conditions. for example between 0 and 100 percent opacity. is this possible? does anyone know example tutorials or else?
    thanks in advance 🙂
    Adam Greenberg replied 4 years, 11 months ago 3 Members · 3 Replies
  • Pau Amer
    September 17, 2021 at 12:23 pm
    What are you trying to achieve exactly?
  • Las Wen
    September 18, 2021 at 3:25 pm
    i wanted to achieve that the scale of the shape layer divides to half or a specific value. Kind of a responsive Comp with breakpoints.
  • Adam Greenberg
    September 20, 2021 at 4:45 pm
    As Pau said, you need to be much more specific.
