Activity Forums Adobe After Effects Expressions if / else expressions to define and control individual text characters
  • if / else expressions to define and control individual text characters
    Posted by Tyler Jack on November 5, 2020 at 11:12 am
    Hi!
    I’m interested in building an animation which involves a single text layer, that could be formatted in a way that is repeatable, no matter how long my text layer is. For example:
    Let’s say my text reads ‘HELLO’ which is 5 characters. Could I (and how do I) write the following
    if text = 5 characters, position of character 1 =, position of character 2 = etc…
    I would then animate positions A and B using a slider, A is the position I set above, and B would always be 960,540, animating in place.
    The expression would be long, each character would have a new x,y for each text length, which I would set up manually, probably up to 15 characters.
    The hope is to have a single text layer, that formats and positions itself without needing to manually decompose text, randomise position, animate in place etc.
    Any thoughts are hugely appreciated – may not be doable but I know some of you have a wealth of knowledge on niche expressions.
    TJ
    Tyler Jack replied 5 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
