Activity Forums Adobe After Effects Expressions if/else condition in 2-dimensional parameters (size)?
  • if/else condition in 2-dimensional parameters (size)?
    Posted by Las Wen on September 16, 2021 at 11:39 am
    ahoi,
    im am learning since some weeks a little bit expressions and i came to the point to understand and use if/else conditions. Now i was trying to put an if/els into the size of an square shape layer.
    I wrote this:
    if((SizeX = thisComp.width) < 1000) {
    SizeX / 2
    }else{
    SizeX
    var SizeY = thisComp.height;
    [SizeX,SizeY]
    no errors, but its not working 🙁
    if i put this into an expression slider for each dimension and connect them to the shape layer it works…
    SizeX / 2
    }else{
    SizeX
    no idea what i did wrong…?
    Las Wen replied 4 years, 11 months ago 3 Members · 4 Replies
  • Praveen Kulk
    September 16, 2021 at 12:43 pm
    SizeX = SizeX / 2
    [SizeX,SizeY]
    }else{
    [SizeX,SizeY]
  • Las Wen
    September 16, 2021 at 2:36 pm
    thanks for your reply
    it works till i resize the comp, but than comes an error: couldn’t turn result into numeric value
  • Pau Amer
    September 17, 2021 at 1:05 am
    What are you trying to achieve exactly? Maybe there’s a different approach for what you’re searching for.
  • Las Wen
    September 19, 2021 at 10:20 pm
    i wanted to achieve that the scale of the shape layer divides to half or a specific value. Kind of a responsive Comp with breakpoints (like in html/css).
