Activity › Forums › Apple Final Cut Pro Legacy › IF CAPTURING VIDEO ON A MACPRO, USE THE BACK PORT
  • IF CAPTURING VIDEO ON A MACPRO, USE THE BACK PORT
    Posted by Jennifer Jones on March 6, 2007 at 3:18 pm
    Here’s a little time-saver for anyone having issues with dropped frames while capturing video to a (first generation) MacPro – After a few hours of trouble-shooting over the phone with Apple, we discovered that the FRONT Firewire port is slower than the BACK (due to the way it is connected to the logic board) – So, if you’re capturing video via firewire and having dropped frame issues, USE THE BACK PORT. Just thought I’d pass that along…
    Jennifer Jones replied 19 years, 6 months ago 3 Members · 5 Replies
  • Walter Biscardi
    March 6, 2007 at 6:51 pm
    Interesting, we’ve captured to both here with no issues.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Bret Williams
    March 6, 2007 at 7:15 pm
    Ditto. This also begs the question what goes into the back port, the deck, or the drive? As it stands right now, on my dual 2ghz macpro I have the DSR-11 attached to the back, and the FW400 drive attached to the front port. No problems at all.
    Is mine a 2nd generation? Is there a 2nd gen MacPro? Just got mine in January.
  • Jennifer Jones
    March 7, 2007 at 5:16 pm
    Hmmm.. I’m not sure – All I know is that it definitely solved the problem when I used the back port (both from a deck and camera firewire), and the support person I was dealing with at Apple spoke to his superiors, who confirmed there were problems with the front firewire ports of the first MacPros – They said they had the same problems with the G5d when they came out – Either way, it’s good you guys didn’t run into any problems, I just thought I’d share for those who were struggling with this issue 🙂
  • Bret Williams
    March 7, 2007 at 6:54 pm
    Are you plugging the camera and the deck into the same port? Via daisy chain? Perhaps the front is slower and just can’t handle the daisy chain. I’ve got a deck in the back an drive in the front.
  • Jennifer Jones
    March 11, 2007 at 2:42 pm
    (like I said, originally)
