Activity Forums DVD Authoring iDVD clips video from FCP5
  • iDVD clips video from FCP5
    Posted by Dave Stalion on December 22, 2005 at 3:54 pm
    Greetings
    I know iDVD is simple but I like the templates so
    why does video exported from FCP5 720×486 have
    black at top and bottom, almost as if it were trying
    to letterbox the images but it’s set at 4:3?
    This is from Betacam, component through AJA IO LA
    to G5 dual 2.3
    DV video captured directly to iDVD using one step
    is good with no black so the problem must be on
    export from FCP.
    Dave
    Dave Stalion replied 20 years, 8 months ago 3 Members · 4 Replies
  • Dave Friend
    December 22, 2005 at 4:10 pm
    Try exporting at 720×480 which is the standard used for DVD mpeg2 files.
    Hope this helps.
    Dave
  • Dave Stalion
    December 22, 2005 at 4:50 pm
    thanks but 720×480 looks the same in iDVD
    blacks at top and bottom, not full frame,
    after export from FCP 5.0.4 in Quicktime,
    uncompressed 8 bit, self contained unchecked.
    It doesn’t seem to matter what size I export
    when previewed or burned in iDVD.
  • Rich Rubasch
    December 23, 2005 at 2:00 pm
    Somewhere along the way the clips were flagged as 16:9…check the columns in FCP and see if one of them is setting the clips to 16:9 anamorphic. Some colums allow you to change the setting for each clip and some don’t. Change them back to 4:3 and all will be well.
    Rich Rubasch
    Tilt Media
  • Dave Stalion
    January 3, 2006 at 7:26 pm
    thanks for the reply,
    I’ve been out for holidays.
    the blacks at top and bottom are not
    set at 16:9 and don’t look the same
    but resemble the old horizontal hold
    adjustment. I wish it were as simple
    as a 16:9 setting.
    Dave
