Activity › Forums › Apple Final Cut Pro Legacy › iDVD and Compressor
  • iDVD and Compressor
    Posted by Brian Paterson on October 27, 2009 at 6:45 pm
    I have spent hours today reading up on making the best quality dvd from my hdv footage. (pal)
    End result was that I proposed to make a self contained quicktime file and burn it at professional quality in idvd. However after hours of reading many more articles on the web I am also toying with the idea of making a self contained quicktime movie and then compressing it in compressor first ( although I have never used compressor).
    The advice after that is to burn the dvd in DVD studio pro. However I have FCP 5.1 which dosen’t have DVD studio pro in it and apparently the stand alone version ( if I could find one) won’t work with my intel imac. So that only leaves me with iDVD ( or toast ) I prefer to use iDVD because of the cool menus so my question is should I send my quicktime file to compressor and then to idvd or bypass compressor and go straight to iDVD.
    Finally, on a short quicktime test I found that on my old television ( as opposed to my newer widescreen one) the image was squished. Is there something in idvd that will sort this when I burn the finished article
    Many Thanks
    brian paterson
    Brian Paterson replied 16 years, 11 months ago 3 Members · 3 Replies
  • Todd Gillespie
    October 27, 2009 at 7:35 pm
    iDVD can’t burn from a .m2v/.mpeg (the files generated in Compressor) only quicktime movies. So using Compressor wouldn’t work with iDVD.
    As for the squished look, check to make sure your footage is 16×9 or not, then adjust the setting in iDVD. Although iDVD usually automatically adjusts.
    good luck,
    Todd at UCSB
    Television Production
  • John Fishback
    October 27, 2009 at 7:47 pm
    Did you check your install disks for DVDSP? I’ve used FCP since v4 and every version included DVDSP.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Brian Paterson
    October 29, 2009 at 10:30 am
    Hi John,
    I have finally found the installation disks but there must be one missing as I cannot see anything for DVDSP. It seems I am stuck on this one with no way forward unless I can get a disc from somewhere else. Even then I am not sure if each disc in each set has a seperate installation code. I.E. would a disc from another set work with my own installation discs.? And where would I get one if it did?
    Many thanks anyway.
    Brian
    brian paterson
