Activity Forums Adobe After Effects Ideas on how to recreate this
  • Ideas on how to recreate this
    Posted by Jackson Redshaw on January 15, 2013 at 2:09 am
    https://shinestudio.com/pitch-perfect-2/
    I’ve tried using Generate>Waveform>Digital but it just doesn’t look right… I can’t get the bars to have square tops, or to look this clear, for example if I zoom up on them with a camera they just look blurry and horrible
    I only want to recreate the first few seconds where it is the waveform by itself, not on the DJ Mixing Interface
    Jackson Redshaw replied 13 years, 6 months ago 2 Members · 6 Replies
  • Viktor Tornfors
    January 15, 2013 at 4:34 pm
    Hi!
    This is easily done with shape layers. Shape layers is a pretty overlooked feature of After Effects. But very powerful.
    I put together a project file for you: https://www.tornfors.se/other/waveform_cs5.aep
    I created a shape layer containing a single rectangle, using the rectangle tool. Then i added some properties to the shape layer. These properties can be found by twirling down the shape layer and pressing the arrow with the word “Add:” next to it.
    I added a “repeater”, which just repeats the rectangle to the required amount. I also added “wiggle transform”, set to only wiggle the scale.
    This way it wiggles the scale of each repeated instance of the shape layer independently, creating the waveform-like effect.
    The background grid is also made with shape layers.
    A great site for learning more about shape layers is Mattrunks. This tutorial is a good starting point. https://www.mattrunks.com/en/tutorials/after-effects/shape-layers-sparks
    22 year old motion designer from Sweden.
    https://www.vimeo.com/tornfors
  • Jackson Redshaw
    January 15, 2013 at 11:45 pm
    Hi, thanks for your reply and help! But is there anyway to make the shapes go to the music?
  • Jackson Redshaw
    January 16, 2013 at 1:40 am
    Thanks Heaps! You’re a legend! Just opened it, will do some tweaking and it will be perfect! Thanks!
  • Viktor Tornfors
    January 16, 2013 at 11:05 am
    No problem!
    If you want to make the bars move to the music, you can do that too.
    Put your song into the timeline. With it selected, go up in the menu Animation – Select Keyframe assistant and press Convert audio to keyframes
    You will now get a Null, called Audio Amplitude. If you twirl it down you got your audio amplitude in keyframes there.
    Twirl down the scale property of your Bars-layer. (I think both the wiggle transform scale and the normal layer scale would work. Play around!)
    On the scale property, put this expression:
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [value[0], temp];
    And it will move to your beat.
    You could also use the plugin Trapcode Soundkeys. It would give a better result, but it costs money.
  • Jackson Redshaw
    January 16, 2013 at 11:42 am
    Thanks for that, I’ll give it a go.
  • Jackson Redshaw
    February 5, 2013 at 6:57 am
    Hey Again,
    Is there an easy way to zoom along the waveform, having multiple text boxes on top as we fly past?
    Jackson Redshaw
    http://www.youtube.com/MITLRproductions
