Activity › Forums › Canon Cameras › ideas on how to get clearcom( or any communications) to XL1 camera op in Live shoot
  • ideas on how to get clearcom( or any communications) to XL1 camera op in Live shoot
    Posted by Paul Harb on May 18, 2005 at 7:40 pm
    Im using an XL1 on this live band shoot and I want to be able to talk to my camera op if possible, how would you guys set this up, this will be at a concert so the lines will be run through people, so it has to be a pretty industrial solution…but not too expensive…
    Paul
    David Jones replied 21 years, 4 months ago 2 Members · 3 Replies
  • David Jones
    May 18, 2005 at 8:10 pm
    If you are running a tether to the camera, then run clearcom from the truck with it,
    and use a belt-pack for the cam op.
    If the camera is free roving, use inexpensive FRS two way radios with headsets.
  • Paul Harb
    May 18, 2005 at 8:13 pm
    ya, Im just running a BNC/compostie to the camera…..can you suggest a model for the 2 way? can you hear with these during a loud concert? And can you talk hands free?
    Paul
  • David Jones
    May 18, 2005 at 9:04 pm
    You can purchase these little FRS radios at places like Best Buy, and some are available with a vox activated mic,
    but that might not be great in a concert setting.
    Can you not just run Clearcom line along with the composite line from your truck and use a belt pack?
    I’m also curious how you are going to feed Genlock to the XL1, Or I guess your not.
    You might also have a look at this website, https://www.unitcine.com/sprint
