Activity › Forums › Apple Final Cut Pro Legacy › Ideas for making the smallest decompressed AVCHD files possible
  • Ideas for making the smallest decompressed AVCHD files possible
    Posted by Noam Osband on January 28, 2011 at 4:22 pm
    I’m working on a project where I need to send someone a lot of decompressed footage to do translation. I need to conserve space on the hard drive, and since the image quality isn’t important for the translator, I want to decompress the files to be as small as possible.
    What are my options?
    I decompressed using the intermediate pro res codec with FCP – what I assume is the smallest decompression AVCHD can do – but the files were still too large to fit everything I want on it.
    The other alternative I have considered is decompressing with the intermediate codec and then running it through Quicktime 7 or Handbrake, some program that can let me further compress QT video.
    Anyone have any other thoughts? Ideally, I can cut out the middleman and make smaller files through just Log and Transfer.
    Nick Meyers replied 15 years, 8 months ago 4 Members · 3 Replies
  • Rafael Amador
    January 28, 2011 at 4:58 pm
    Use QT Player and make some H264 with reduced size (320×180) Make them “One Pass”. Data-rate 200Kbps and “Key-frames: AUTO”.
    rafael
    http://www.nagavideo.com
  • Olin Padilla
    January 28, 2011 at 5:43 pm
    Rafeael’s settings sound pretty solid.
    Remember that you are doing two things here:
    1) Transcoding the AVCHD media to a viewable/editable format.
    2) Compressing for small file sizes and an easy send.
    Since you already transcoded to prores (and I assume you are going to edit with that footage), you should use the .mov files created form the first transcode to compress to h.264.
    I wouldn’t recommend Quicktime for the compression, since it doesn’t allow for easy batches. I would use Compressor or MPEG Streamclip.
    Also, don’t forget to convert the audio to the AAC codec. You will be amazed at how much space that will save.
  • Nick Meyers
    January 29, 2011 at 5:26 am
    VIDEO: you can also cut your frame rate in half
    AUDIO: as Olin says, dont forget to compress your audio.
    make it mono,
    and experiment with quality
    nick
