Activity › Forums › Apple Final Cut Pro › Ideas for extra shortcutting the Move Playhead to a Timecode function
  • Ideas for extra shortcutting the Move Playhead to a Timecode function
    Posted by Marco Noe on January 23, 2024 at 1:48 am
    Hello,
    Can anyone think of a way to avoid having to enter 00 at the end of each timecode when I use ctrl+P to shortcut the Move Playhead to Timecode function?
    E.g. I want to go to the 23 minute 05 second mark of my clip. Under my current workflow I press ctrl+P then 230500. That’s because final cut has the timecode format HH:MM:SS:FF and fills from the right hand side. How can I adjust the inputting of my timecode so I don’t have to specify frames (FF)? Long shot I know haha…
    Marco
    Marco Noe replied 2 years, 7 months ago 3 Members · 4 Replies
  • Ben Balser
    January 23, 2024 at 4:54 pm
    Use periods in places where a colon or semi-colon would go. So 00:04:25:00 could quickly be typed in as 4.25. then hit enter, and FCP will fill in the zeros for you. Very fast.
  • Marco Noe
    January 24, 2024 at 2:38 am
    Great thank you! You’ve just halved my button pushes 🙂 thanks Ben
  • Brie Clayton
    January 24, 2024 at 3:13 pm
    Thank you for solving this, Ben!
  • Marco Noe
    January 30, 2024 at 6:25 am
    Hey Ben and Brie,
    I’ve just come across the paste timecode function. If your transcript timecodes are set up correctly then you can simply copy the timecode from your transcript and then all you’re doing in fcp is using a shortcut to paste the timecode in which moves the playhead to that point.
    My previous workflow has been look at timecode, use move playhead short cut, type in timecode!
