Activity Forums Adobe Premiere Pro Ideal Hardware Upgrades to run Premiere
  • Ideal Hardware Upgrades to run Premiere
    Posted by Tristan Finn on March 28, 2019 at 7:34 pm
    Hey CC,
    I’ve noticed that the edit bays at my work could use a update to have them run faster and smoother as they are starting to run a bit slower. I’m unsure if my boss would fully upgrade everything so I was hoping to find out what would be the best thing to upgrade first. CPU, RAM or Hard Drive? Our edit bays are all identical so here are the specs below.
    A side note is we tend to edit using 720p/1080p Pro Res & DNX HD with occasionally MXFs, I know in a perfect world we would transcode everything down to small proxies but that’s a whole other can of worms, so just assume we will be cutting using the media specs above.
    HP Z420 Workstation
    Windows 10
    Intel (r) Xeon (r) E5-1650 v2 @ 3.50GHz 3.50 GHz
    32GB RAM
    64-bit Operating system, X64 based processor
    Running Premiere 13.0.2
    Internal HD is a SSD Micron Model# MTFDDAK512MBF-1AN1ZABHA-HP
    MICRON 512GB MLC SATA III 2.5 INCH SMALL FORM FACTOR SFF M600 SERIES 16NM MULTI LEVEL CELL NAND FLASH 6GB/S SATA3 SOLID STATE HARD DRIVE SSD
    Secondary HD (non SSD):
    SEAGATE ST1000DM003 P/N: 1ER162-501 F/W: CC45 1TB TK Z4Y DESKTOP HDD
    I’m interested to know your thoughts. Will upgrading one thing really help or is it more along the lines of needing to upgrade all three parts.
    Tristan Finn replied 7 years, 5 months ago 3 Members · 4 Replies
  • Shane Ross
    March 28, 2019 at 8:37 pm
    You don’t mention what GPU (Graphics card) are in these machines. Premiere really does leverage the GPU to help things go smoother. CUDA…the “Mercury Engine.” Those are the terms used when Premiere taps into the GPU to help with editing.
    So yeah, what GPU do you have? And you might do good to get a better one.
    Shane
    Little Frog Post
  • Tristan Finn
    March 29, 2019 at 12:24 am
    Ah yes so the systems have
    NVIDIA Quadro K2000
    And we have a I/O card
    Black Magic Decklink Studio 4K
  • Ryan Holmes
    March 31, 2019 at 3:17 pm
    [Tristan Finn] “NVIDIA Quadro K2000 “
    Upgrading the GPU is almost always a no-brainer. Grabbing a GeForce GTX 1080 or similar would increase your usability and lower render times without a huge hit to the piggy bank.
    Puget Systems has some great benchmark tests and recommendations that you may find helpful:
    https://www.pugetsystems.com/recommended/Recommended-Systems-for-Adobe-Premiere-Pro-CC-143
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Tristan Finn
    April 1, 2019 at 6:27 pm
    Thanks for the info Ryan!
    I wasn’t sure if CPU or GPU was better to upgrade first. It looks like replacing a CPU on a HP Z420 with a new one might require a motherboard replacement as well. I’ll be taking up some video card options to the boss this week.
    Cheers ????
