Activity › Forums › Apple Final Cut Pro › Ideal Blu Ray settings for large projection in FCPX
  • Ideal Blu Ray settings for large projection in FCPX
    Posted by Paul Hanssen on October 19, 2015 at 2:46 pm
    I have to make a blu ray disk for a projection in an art house cinema. Does anyone know which settings are ideal?? I can use the standard settings but perhaps I can set them manually in FCPX for higher quality.
    Best Regards
    Paul
    Bret Williams replied 10 years, 11 months ago 4 Members · 5 Replies
  • Noah Kadner
    October 19, 2015 at 5:40 pm
    Not a whole lot of leeway if you want it to play in a Blu-ray player. Better if they let you hook up a laptop and stream ProRes over HDMi.
    Noah
    FCPWORKS – FCPX Workflow
    FCP eXchange – FCPX Workshops
  • Doug Metz
    October 19, 2015 at 7:48 pm
    If you have Compressor 4.x (well worth the $50), it has a built-in BluRay setting – which you could set up as a Share destination in FCPX preferences…
    Doug Metz
    Anode
  • Bret Williams
    October 20, 2015 at 12:54 am
    Same blu-ray settings are already in X, aren’t they?
  • Doug Metz
    October 20, 2015 at 1:58 pm
    [Bret Williams] “Same blu-ray settings are already in X, aren’t they?”
    Well, how about that? Hadn’t seen that in the Destinations pane before… looks like there are a few more configuration options via Compressor if you’re so inclined.
    Doug Metz
    Anode
  • Bret Williams
    October 20, 2015 at 2:00 pm
    Same interface / options that was is FCP 7 / Compressor 3 too. Almost exactly.
