Activity Forums Adobe After Effects Idea how to connect both shots
  • Idea how to connect both shots
    Posted by Bob Tanner on December 2, 2014 at 11:14 pm
    I have two shots that I filmed.
    I printed out a screenshot of the video and had the actor hold up the photo frame and the camera slowly rolls into him.
    The next shot is the actual video,
    How would I smoothly transition from the first shot, to the secod?
    Stephen Smith replied 11 years, 9 months ago 3 Members · 2 Replies
  • Xdominguez Pukkas
    December 3, 2014 at 11:02 am
    Does the camera arrive to a really close up of the picture?
    If it doesn’t, then I would use a virtual camera adjusting its focus to the picture, so everything else gets blurred (and the pixelation is not too blatant). I would center the camera to the frame, and use a slight transition from the picture to the footage once the image fills all the frame.
    I see that the picture is held slightly backwards, so you will have to adjust the perspective in order to match the picture with the footage.
    I hope that works.
  • Stephen Smith
    December 4, 2014 at 7:08 pm
    It may make the transition more seamless if you place the real photo in the frame. So you don’t have to line up the real photo with the one you want to add digitally. This can be done with the 3D tracker. Check out this tutorial for more and best of luck:
    https://library.creativecow.net/articles/mcauliffe_kevin/AE_Camera-Tracking/video-tutorial
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
