Activity › Forums › Adobe After Effects › ID Matte and 16/32 bit
  • Amit Zinman
    April 29, 2008 at 4:37 pm
    No, I’m at the AE end of the stick
  • Amit Zinman
    April 29, 2008 at 5:09 pm
    No, previous projects used a color map instead.
  • Amit Zinman
    April 29, 2008 at 5:27 pm
    I am trying to avoid working in 8-bit, and it would be difficult for me to convince the 3dmax people to change the way they do things since I am merely a freelancer. I was hoping to locate a third party tool.
  • Darby Edelen
    April 29, 2008 at 9:47 pm
    [Amit Zinman] “I am trying to avoid working in 8-bit”
    Which is a good idea when you’re dealing with additional channels out of 3D renders. The more information the better!
    If I understand the ID matte properly, a work around might be to extract the ID channel. Then use Curves to push all values to black except the value you want to reveal and then use that image as a luma matte or as the input for a Channel > Set Matte effect.
    The curves effect you use might end up looking something like this:
    It seems odd that Adobe hasn’t enabled the 3D Channel effects for 16/32bpc… I would think they’d be some of the most important candidates.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
