Activity › Forums › Adobe After Effects › i9 or threadripper on after effects CS6? Is downgrading a solution to multithreading?
Cesar Siena replied 8 years, 4 months ago 3 Members · 12 Replies
Walter Soyka
April 18, 2018 at 10:36 am[Cesar Siena] “The video presented a machine with 32 cores (or threads?) and the host (presenter) worked flawlessly in real time. How do you manage that?”
You mostly don’t. There’s very little that’s real-time with Ae in the real world, no matter what hardware you’re using, unless you are doing very simple work. There are only a couple situations where real-time or near real-time work is possible: relatively straightforward effects on the current releases of Ae (where the GPU accelerates the effects), and demos of limited complexity.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Cesar Siena
April 18, 2018 at 11:00 pmThanks, Walter. This is a relief to avoid day-dreaming with utopic machines.
